Pump 255 pump ?
omarblackg50
Car: 1994 q45
Pump just came today but....its a lot smaller than o/e.How do you keep it in pump assembly?Hose is rather short,guess I have to use original.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If you didn't get OEM pump, good luck!
Rex
Car: None
Not sure any of the G50-regulars are using an aftermarket pump.
Assuming yours is dead, any chance you can mount the non-OEM one to the OEM plate??
omarblackg50
Car: 1994 q45
Its about half the size of o/e.Maybe i can rap a bunjee cord around it like a seat belt perhaps?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
There are some people that tired this so you may want to search.
omarblackg50
Car: 1994 q45
now Paul you are the x-pert at tinkering I thought at least YOU would know....
Infinitiguy19
Well I like to make things better where I can. But the fuel system requires much more research.
Look at the link in my signature and see if its listed in on of the hundred documents.
omarblackg50
Car: 1994 q45
Did research 255 fuel pump walbro etc.But no mention about mounting using factory a**.just mentioning some modification,assume 2 wire lead clip doesnt look like it will snap in to fac harness.Will b out in the morning installing parts on her,and preping for plennum removal went ahead and ordered 12 injectors........Earlier I Put in a new battery and I noticed what looked like that white stuff that is on battery terminals on the side of the engine where the pullys are.It was in powder form like baking soda or columbian white.Car has sat for a few months so tomm.replacing fuel pump hoses, fan clutch, fuel filter and lube external moving parts till injectors arrive have 2 knock sensors, anyplace other than ios sell harness would b of help.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Any Infiniti dealer will sell you the KS sub harnes for more money gladly!
