ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Oct 01, 2010 8:21 am
Platinum plugs are good I use them only in #6 position because of the long term life, but they must be cracked every 2 years and must be installed with anti-seize compound because aluminum from the head can and does stick to plugs and if not cracked or anti-seize compound can be a costly repair.
The amount of power, heat dissipation, plug length, if kept to spec will not change much from regular plugs but maintenance will be less...but if you maintain your own vehicle with regular plugs you will see a rise in costs.
Also a single spark compared to a triple spark plug will put extra load on coil(s) as the spark area has 3x the area to build up electrons, but a single platinum wire that is tapered compared to a square ridge will fire at a low electron build up and the shape of the platinum tip is self cleaning. But
All said if you are doing regular maintenance the benefit is minimal with added expense.
