Milliterate »
https://forums.nicoclub.com/milliterate-u139899.html
Thu Aug 25, 2011 6:28 pm
I've searched and can't find any threads with the exact same problem as mine. My s13 just recently started pulsating and making a light thumping noise under medium to heavy braking. I can feel the pulse in the pedal, so I thought it was a warped rotor or uneven pad wear. I've replaced the front rotors and brake pads and bled the brakes, but the problem still exists. I don't believe it is the rear brakes, as the caliper sliders are seized on both and they honestly don't hardly work at all, not to mention, the caliper bracket bolts are sheared off, so I'd have to get an entirely new spindle to replace the rotors. It sounds like the thumping is coming from the front as well.
This seemed to start after I put new struts on the front. I've double checked all the nuts and bolts and everything is tight up there. I had the front on jack-stands for about a week with the struts pulled out and the control arms hanging only from the sway bar and tie rod, could that have damaged the sway bar bushings? Would that cause a stuttering front end when braking? I can't figure out what this might be, or why I can feel it in the pedal. Help!
