I'm going to have to cut up my radiator support soon and customize the hell out it because my T28 is bigger and slams my radiator
I do have a custom manifold, but the pulsar's have more space than the B12 sentra does. I mean, the sentra a crap for space, so my manifold had to be made with the bigger turbos I use. But in Liquid's case, maybe he's using the RWD manifold which will indeed throw-off the turbo placement for the fwd applications. I use to run a T3/T04B oon a flange welded to the stock AWD CA18DET manifold and it fit pretty good with the slim fans.float_6969 wrote:I'll bet it's the exhaust manifolds. Aren't you running a custom tubular manifold Dee?
Never saw how the RWD manifold places the turbo on a FWD application. The KN13 pulsars have more frontal space than the B12 sentras, so that's where my comment comes from. An AWD/FWD manifold will give you better placement, but if you've gone this long with that platform, just go with what's available because those AWD/FWD manifolds are rare; very rareLiquid_Neon wrote:RWD manifold is my setup... i got the rwd ca18det from you dee :P
as you see... it is sitting in a little dent that was fored into my radiator.
Look like they welded a bung onto the oil pan of a USDM CA18DE and used the oil tube from the USDM pulsar and the engine seemed to have starved for oil due to pick-up placement. And the capacity of the DE's oil pan is less than that of the DET which all played a part in starvation. Also had some trash in there as well. Block is good, crank will go the machine shop.Liquid_Neon wrote:Uh oh? What parts got mixed dee.... is it like my setup? De pistons in a det block?
