blackmax23 »
https://forums.nicoclub.com/blackmax23-u66692.html
Mon Feb 25, 2008 9:19 am
Pulleys don't add hp, they only free up hp. What was said above was correct. All that's happening is you are "underdriving" certain accessories, so with the less weight, less rotational mass, and less work it takes to spin the accessories, it results in the engine not having to work as hard to spin everything else, so it frees up hp. It can put more stress on your altnernator, especially if you have an aftermarket sound system with subs. For the amount of work it takes to put a new one on (taking the front tire off and finding someone qualified enough to get a pulley puller tool and do it right without damaging parts), it's really not that worth it. You might see a gain in whp of about 5 at most. A y-pipe is def. more worth the money than a pulley. Warpspeed sells great y-pipes for reasonable prices, check them out.
