Pulls with my KA-t on New years eve
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
yea new years eve. I just realized i have not gotten any footage of my KA-t so i went out with my digi cam and shot some quick pulls
note: the over reving and jumpy tach needle is do to an leak in my intake manifold that ill address soon.
http://www.youtube.com/watch?v=LlGxasnlbDM
Tulsa_S-13
Car: 1991 SR 240sx
Awesome! Looks like it's fairly healthy. Have you had time to take it to the track yet and see what e.t this setup gives you?
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
yup
13.7 @ 104mph @ 6psi
Modified by Biggamehit at 6:47 PM 1/1/2007
Tulsa_S-13
Car: 1991 SR 240sx
Awesome time!
I couldn't help but notice that after looking at the pics you have on your CarDomain your chassis looks alittle bent.
klattr1
Car: GT42R powered S14/KA
pulls pretty good...seems like your clutch is slipping some though
KATwo40
Car: 1993 240sx KA-T
Yep...looked like some clutch toasting to me, too, Klattr.
Nice vid, good pull for 6psi.
Poor_S13_Driver
Car: S13
Perfect little video. Looks awesome man. Geez i would be perfectly happy with 6psi lol
boznuttz
Car: MS13
Wow. How IS the xs turbo and manifold holding out? I plan to go a similar route as long as I weld the flange further away from the BMC and reinforce the damn thing. Also, where did you mount the XS BOV and MAF for the SAFC, how is it running?
Modified by boznuttz at 1:18 AM 1/2/2007
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
6 1/2 months no issues.
about the clutch i thought it was that also. but i just installed an ACT Xtream racing disk about 3 months ago. its deff the leak. when im out drifting around it bits hard and holds up to all the clutch kicking and i can drive it home with no issues.
dude when i got to the track the first time, the clutch was not ready and i slipped all the way down running an f-ing 17. so pisssed, and then 2 weeks later I ran again and turned the 13.7
oh yea that bend is the strut tower, im resetting that this coming week
Modified by Biggamehit at 1:05 PM 1/2/2007
Florida240sx
Looks like clutch to me as well...Any dyno? Where is the intake leak at? nice video nontheless
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
the leak sound to be coming from inbetween the lower plenum and runners, i have the gasket. the clutch it fine.
Florida240sx
I'm just confused on how a 6psi is faster than my 10psi with cams... I'll see what my track time is....
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
yea dude everyone was saying that about my time. but it struggels to even hold 6 psi lol. i mean my car is fully striped of any un-needed material maybe thats an reason......
Riubens
Car: ka-t 240 and 99 Q45 t
dam! thats really amazing at only 6psi.
Florida240sx
Your time sounds right, just the video of the tach I don't think is right... Just go to the track again and when you cross the line look at your speed and see what the time slip says...
ghx407
Car: 1993 240SX KA-T
Those are awesome numbers, but for your own safety I would suggest you consider dropping your motor and setup into another chassis.
SeanC
Car: 1993 240sx SE
what i find odd is that it pulls past 5800 rpm most stock ka's without cams stop pulling about there with stock intake manifolds...
Tulsa_S-13
Car: 1991 SR 240sx
Speaking of stock manifolds, I just picked up an Xcessive Intake manifold for my KA
Sorry to threadjack
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
no problem. i removed the secondary butterflies if thats makes an difference either.
yea dude im looking for another coupe. but this one is fixable. ill post pics after i fix it.
my highest speed trap was 105mph that day.
KATwo40
There's a lot to be said for 60' times, Florida240sx. If your 60' is low, your ET is low.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
with some drag tires, my time would lower. but i could car less about drag
Florida240sx
I'm just going by watching the video...he is going from 0-105 in 10seconds... But he runs a 13.5second at 105.... Not calling BS on his times or et. *I'M* thinking clutch slippage on the video of the tach..Fix the boost leak and then do another session, if it was the issue then there shouldn't be any jumpiness....
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
its cant be the clutch, it grabs well.... it would def slip at low-mid rpms also. and like i said i can go out drifting and clutch kick it alll day and drive home with no issues. i installed the clutch ( act xtream racing clutch) with an brandnew lighten flywheel( 11lbs XTD ) at the same time.
i have all the slips from that night if you would like to see em
i ran the 13.7 when it was warm out
and then an 14.1 and 14.0 ( cold out and not able to adjust my fuel, no wideband for accurate adjustment)
when i ran the 14.0 i got an trap speed of 105 i cant explain that lol
Florida240sx
My friends clutch grabs well too and then slips at higher rpms...I'm done arguing with you #1 it's not my car so I'm goign by what I see and read, I'm not there to experience it. #2 the is another issue at hand that you know of, until it's fixed it's pointless the continue. Being you have a leak at the mani your boost gauge reading could be off and your running more psi than you know of??? Too many variables.......
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
not arguing dude. just here to have an 240 good time
update.
i took the car out for an long drive today to pick up parts i needed to fix my issues and it turns out that the clutch is acting up. after about an hour of driving things heated up and i began to slip at low-mid rpms a bit.
Modified by Biggamehit at 1:26 PM 1/4/2007
klattr1
oh, id believe it
Florida240sx
Biggamehit wrote:its cant be the clutch, it grabs well.... it would def slip at low-mid rpms also. and like i said i can go out drifting and clutch kick it alll day and drive home with no issues.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
yea but I have not driven the car for long periods of time since the install. i hardly leave base lol
