Pulling the wiring harness ???
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
How do you get the wiring harness from the ecu through the front firewall?
Do you have to take all the AC components off to do it?
Ive got all the connections loose, but found a vinyl floor in the way... but I see where it goes through, but the rubber stopper is next to impossible to get out without knowing the trick...
Josh
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
We pulled a KA from two cars, threw one away and swapped the other into the other car a couple months ago. You disconnect the harness from the ECU and pull it through the firewall. It will get hung up but you just have to be patient and work it through. Both cars had all A/C components and we didn't have to move anything.
Acecool
Yeah, I am stuck at that stopper :-)
Ill work on it once I get home again, thank you :-)
Josh
positron1
If I remember correctly, get a screwdriver or something and use it to pry the edges of that rubber stopper away from the chassis so you can push it through the hole in the firewall and then you can pull the harness upwards.
Acecool
Got it out by brute forcing the stopper, and I took out the glove box because near the round ac motor thing on the right hand side at the firewall the harness is attached to something with a plastic stop...
I brute forced that off with 2 screwdrivers and it pulled RIGHT out :-)
So, harness is out and all the fluids are drained, now just to unbolt and pull it out.
Josh
thanks all
