bruinbear714 »
https://forums.nicoclub.com/bruinbear714-u1106.html
Sat Nov 30, 2002 12:00 pm
you have to remove the intake tubing/hoses, radiator shroud, radiator fan, and all the belts.
Then you have to remove the crankshaft pulley. Then the bolts holding the front cover to the engine.
It sounds easy (and it is if you have done it before), but it will take you a good 4-6 hours if you never pulled the front cover off before.
Oh, and make sure you get a new front oil seal along with the timing kit when doing it.
