Pulled lots of rwd motors and always drop the transmission first.... except for projects like my rwd corolla and starlet where the top of the radiator support can be removed, so the motor/transmission assembly can be quickly "slid" out.With the CA18 auto I left the transmission supported, plucked out the motor and returned it, no problem.I don't mind lining up a transmission/gbox onto the intalled motor, and I work alone and don't even have a lift.
r34 gtr wrote:I would imagine it sucks. I have to change my front one out over winter break, and am not looking forward to it. Its totally doable, especially with the engine out of the car, but it will require unbolting the main caps and lifting the crank up enough to put new seals on.
you don't have to touch main bearing caps or lift crank to change the rear oil seal. That's required for the front seal ?I'd leave the motor in, drop the gbox, remove the flywheel and there is the seal/housing staring right at ya
