Pulling out a Ka24de
Benjketsa31
Car: 1990 240sx hatch
Hey guys as the title states could i pull it out without using a engine lift? Like can i just take it apart piece by piece? If i can would anything drop out of the top end from the bottom when i lift it off the block?
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
have you ever bent over to pick up a 2 1/2ft by 1ft by 1 1/2 ft chunk of iron?
if you have alot of strength and no fear of back problems, go for it.seriously tho, use a lift. easier, safer, plus, dismantling it then putting it all back together just isnt worth it.
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
Yeah, even the block in it's bare form would be pretty heavy, plus your talking about having bend over the fenders or stand in the engine bay and try to move that thing whereas either way you would have little to no leverage..
If you've got a decent sized tree that runs horizontal just grab a come-along and some chains and presto!!
Definitely try to get a lift, find a friend of a buddy and borrow one, or hell see if you can't rent one, I'm sure some place does it.
480sx
Car: 1996 Pearl White 240sx
No is the answer to your question. You could drop the subframe+ engine, but you need a lift to do that.
