PULLING MY PLENUM OFF NEED HELP!
Cincy_300zx
Car: 1990 2+2 N/A 300zx
I have recently learned that I have a bad fuel injector so I have decided to replace all 6 of them so I started to take everything apart following the guide from tt forums, I am almost 100% positive that I have everything off that is holding it on and it wont budge the left side is lifted up a little but the right is stuck. Any suggestions on how to fix this do I need an engine lift to help pry it up or am I missing something?
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Before you go trying to pry it like I did, did you make sure to remove ALL 8 bolts? When I did mine, I had removed 7 bolts and forgot to remove the funny looking one. I can't find a picture of it, but its like a bolt with a really tall head that's used to hold one of the throttle cover bolts.
It's also possible that you forgot to disconnect one of the vacuum/coolant/PCV lines. Is this the first time the plenum has been off?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Also the side brackets. Those can be easy to forget. And EGR. And coolant lines. And all other kinds of stuff.
ThisIsSparTTa
Car: 91 300ZX TT 2+0
If your plenum is sealed with RTV you might have to stand up on the front, near the headlights and pull really hard. That's what I had to do when I resealed mine with RTV.
FGhumanNYC300zx
Car: Partially built 91 300zx TT, 507 rwhp
I remember the last time i replaced my injectors I used the Dremel method. It saved me a lot of time and will make it easier to replace in the future
Anthony.G.
Car: 300zx 91 body, 94 engine
Supra 92 body, 91 engine
If you still need help with it, Here's a PDF for the "Dremel Method"
I've pulled my plenum a couple times now... make sure you label EVERYTHING! take a piece of tape and write where everything goes.
It is way too easy to forget a vac line, and your engine will run like crap.
http://www.mdsmarthome.com/z/Z%20Tech/Z ... Method.pdf
