BigTDogg (MA) »
https://forums.nicoclub.com/bigtdogg-ma-u74746.html
Sun Mar 07, 2010 1:28 pm
You can pull engine and transmission together, but IMO, it's easier to pull transmission first then pull engine. Because then you can just go from hoist directly to engine stand.
To drop the transmission, loosen the 6 bolts holding the mount, with a floor jack under the mount damper cylinder thingie supporting the weight. Then remove those 6 bolts and slowly lower the transmission down with the jack. Loosen the motor mounts too give you more of an angle (optional). Then use 36" to 40" of extensions and a 14mm swivel socket (the kind with the universal joint built in is best) to remove the upper two bolts. Once you've done it once, it's really not that bad.
A transmission jack is safer and more stable, but with two people, you can remove the transmission with just a floor jack, with the cup placed under the drain hole.
Now getting them back in... That can be fun.
