Yeah, PITA but, no choice. I have the axels out. Pull the dif this weekend.I have new struts,and the breaks have been done,calipers,pads,lines, ande- brake cables. so... with the diff rebuilt and the new mounts and universal joints replaced,and axels lubed w/new boots,the rear suspension should be a lot tighter.evildky wrote:nothing lasts forever, it's a PITA to get the diff out but if you geot a knock you have little choice, it'd be nice to locate an 87.5-89 CLSD
Thanks for that input. Any suggestions as to where to get those bushings?I'm thinking http://www.courtesyparts.com/evildky wrote:you might want to take a look at the crossmsmber bushings and trailing arms bushings while you are doing everything else
Thanks!evildky wrote:dealer only for the stockers, msa, and BD also sell OE aprts and might have urethane alternatives
Thanks for the suggestion I will check that out.zxman69 wrote:I'm going through the same thing . check your subframe bushings. there was nothing left of mine. you can still get them at nissan.
Thanks for the advice and the compliment.evildky wrote:and nice Z31
Thanks mtnhighus! I brought it to a local transmission shop. They said that it would be ready tomorrow.mtnhighus wrote:if you have a NAPA store with a machine shop close by they will pull and press on your new bearings for almost nothing, did some in a truck of mine a couple of years ago, cost me 15 bucks for 3 bearings.
Would be nice but...I don't think Santa is going to bring any pinion bearings.evildky wrote:might want to go ahead and get the pinion bearing, thts the most common point of failure and with the longsnout r200 it's under a lot of strain
are there shims under the bearings to adjust the pinion depth, and ring gear carrier housing? i've rebuilt a couple of rear ends but this is the first nissan i've seen the inside of. looks pretty straightforward.evildky wrote:might want to go ahead and get the pinion bearing, thts the most common point of failure and with the longsnout r200 it's under a lot of strain
Thats too funny. I could just send you the cleaner but, I don't think I have any left.evildky wrote:wow, thats opurty, how many hours were spent cleanign that diff cover? and you wanna trade ti for a dirty one
