silvia s14.5 rb25det »
https://forums.nicoclub.com/silvia-s14-5-rb25det-u95407.html
Fri Jun 26, 2009 6:51 pm
are you talking about the mount or the mount bracket that was broken in half?are you just replacing the mounts? if your not doing a motor build then you can just get factory mounts at carquest for a decent price. Or if your doing a motor build, and you want to up grade to a stiffer mount, and if your on a tight budget, you can go with some hockey puck motor mounts. works great.
on either side of the bock there is a bracket with a single hole in each. on the mount itself there is a bolt sticking out of it. the bracket with the one hole in it sits on top of the mount and a nut threads on the bolt sticking out of the mount.
if you want to save more money and sacrifice a little bit of the smoothness in you ride(unless you have really good suspension) i made hockey puck mounts for 20 bucks.
