pulling mounts out of 91 hatch
driftneil
Car: A pile of cars.
Whats up Nico, I just pulled the motor out of my 91 hatch. After it was out, I was cleaning up the bay. And the driver side mount was broke in half. I cant seem to find where it bolts to. Or do I have to drop the crossmember? Someone help, I need this motor back in asap.Thanks
Osirux
Car: 1992 NA Miata
Bump for importance.
Hope you fix it man.
driftneil
Thanks allot bro, I really appreciate it
sommmatt
Car: 1989 Nissan 240SX
Sigh.
1 bolt from the bottom. 1 bolt from the top. If it broke you need a new one. Crossmember doesn't have to come out. You'll need an impact gun, at least I did when mine broke, otherwise they twist too much.
Uberck
Car: 240sx
yea when i pulled the ka mounts they are bolted to the x member. no reason to drop the member unless you f***in rounded the head or broke a bolt then its drill and sawzall time
driftneil
sommmatt wrote:Sigh.
No need to "sigh" cheif, I Have pulled many motors out of 95's a couple 96's and a 97.And they all were real easy to get to. Maybe Im being a retard, but I can't find the lower nut on this 91. If I cant find it tom, I will post pics.
driftneil
Uberck wrote:yea when i pulled the ka mounts they are bolted to the x member. no reason to drop the member unless you f***in rounded the head or broke a bolt then its drill and sawzall time
Huh, I didn't even think of a sawzaw. Had it sitting there too.
n240sxfnatic
its a 14mm and its a b**** to get them off if they have never been loosened. get an extension and breaker bar and go.
S13Joe
Car: 92 Coupe
I broke my driver's side mount when i was pulling the sohc out of the 89. Just like everyone said, one nut on top and one on the bottom. The driver's side is harder to get to than the passengers because of the PS lines iirc. They should be 14mm nuts.
S13Joe
Car: 92 Coupe
Oh I sent you an e-mail about a pilot bearing too.
zeause
I always strip the passenger side for some reason. Damn nissans
driftneil
Thanks to all, I must have just been out of it at the end of the day yesterday. I looked today, and saw its the same as the s14's. Sorry to post and mods can lock.
