JohnnyDrifter »
https://forums.nicoclub.com/johnnydrifter-u78975.html
Wed Nov 07, 2007 3:00 pm
Hey i just got done I pulled everything out, it went smoothly. The only problem i did have though was i got the shifter lever hung up, i didnt realize you had to remove that. But everything went smooth and the best place to remove the Drive shaft is at the Carrier bearing the 4x bolts.
