Pulling ECU codes.
iliketocrash
ok... i'm not sure how to do it and i don't know what any of the codes are... i tried using the search function for the CA forums and the only thing i came up with is "ok, make sure the screw is all the way counter clockwise. now turn on the car start the car ! then goto Ecu turn clock wise, now it will beep in a beep beep, beep beep beep , beep beep beep beep, and so on, fasion. let it beep three times then go counter clock wise , then it will blink the codes" and that was posted by slw240sx. I'm even a little confused by that, because my car doesn't start. So do i just try to start it, then leave the key in the start position and do the ecu mode switch thingy. So if someone could clarify that for me and/or give me a link to a site with all the ECU codes, that would be GREATLY appreciated.
boost_boy
Turn your ignition to on and make sure all your dash lights are on. Go to your ecu and using a screwdriver, turn the little screw clockwise and watch the sequence of the red and green light. After you've seen them flash 3 times simultaneously, quickly turn the screw back counterclockwise and the codes will begin flashing via the red and green lamps. Count the # of flashes on red and then the # of flashes on green. After the green lights flash, the # flash sequence will more than likely change to show a new code. But if there's only one code, the sequence of flashes will repeat itself.
Dee
rico05
Car: 1992 RMS13 w/ CA18DET
Tell us the code and we can tell you what it is. Get a FSM. They are great fun to read for hours on end!!!
