Pulling codes
ryah
Car: G20
I have a 1992 G20 that I want to pull from. I know I can not do it with an OBDII meter. Can someone tell me what meter to use and where is the plugin port for said meter?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You can also do it with the ECU. The 92 G20 is OBDI and the port should be located underneath the steering column.
turbonxsx
You need to look into buying a nissan consult cable and some software for a laptop and connect into your consult 1 plug-in under or by your steering wheel usually off to your left of steering wheel...
