lazyfcker wrote:ok well im looking to gain more power so i'm going to invest into the camshaft pully. It doesnt seem to hard to replace, should be close to a couple bolts and what not correct? i'm leaning towards the Unorthodox Racing pulley(Crank Pulleys (Ultra S)), is there better?
hmmm are you trying to talk about pulleys or cam gears? camgears are for the camshafts... you usually only get cam gears if you have upgraded camshaft.. it helps you finer tune your timing.
as for pulleys.... just like 9240sx said, the Crank pully and Water pulley are the ones that really help with power. unorthodox is a good Crank pulley, not sure about water one.
