Pulley? suggestions please
daniel240
Car: cars/motocross
ok, i just need some suggestions on what to get. should i get the set of 4 pulleys for like $400, or just the crank pulley for $100, am i going to get that much more hp from the 3 more pulleys, or is the crank pulley going to make the majority of the power? basically is it worth the $300 more?
SkillaSX
Car: Cars, Sports, Women
Yes I would also like to know this!!!
240marcuSX
Car: E34 525i
E46 M3
can you post a link to where you saw a pulley kit, please.
Ive never seen a pulley kit for our applications, and am curious now myself.
SkillaSX
Unorthodox makes a crank pulley and I think Enjuku makes a kit.
daniel240
Car: cars/motocross
U/R makes a 4 pulley kit and enjuku has it for like $400, they also sale the crank pulley individually for like $140, ASP sales the crank pulley for $100. Does anyone have any suggestionsn for me??? anyone?
Structure240sx
ur sig says u have asp pulleys already. but on U/R site they say 85% of the power is made by underdrving the crank pulley then the rest is by the lightweightness of the acessory pullies. im pretty sure thats what it was
Aries
Car: LT1 240SS
when you do the crasnk pully only, you tend to have problems with the alternator and power strreing pumps being overworked.The extra pulleys in the set are overdrive pullies for your accessories.
Personally, I would rather spend the extra cash to get the pullies as a set than spend twice as much to replace a power steering pump and alternator later on.
_dk
Car: 1991 RB20DET coupe
anyone have info on why the UR set supposedly only works for S14 KA's?
solid
I have ur pulley kit for my 95. Nothing has gone wrong yet, i 've had it for a year now, pretty happy with it but dont really know how much hp i got from it, never dynoed. It did help the car out because i felt a difference.
daniel240
Car: cars/motocross
actually ive had the asp crank pulley for a while, just havent had the time to put it on, and i was just wondering if it would be better to get the kit from U/R, but i think ill save the $300 and just keep the asp, by the way, anyone know which belts need to be replaced with the asp crank pulley and the sizes???
Structure240sx
all of them. it should have come with the part numbers or maybe that the U/R
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
daniel240 wrote:...anyone know which belts need to be replaced with the asp crank pulley and the sizes???
A/C belt remains the same size - ASP was nice and didn't under drive your A/C...it's free-wheeling anytime you're at WOT anyway.
But the other 2 belt sizes can be found on...drumroll please...the ASP website!!! - Here's the link directly to the KA install page... :D
Good luck - Brian
daniel240
Car: cars/motocross
oh think you, haha i must have not seen them on the site, i was kinda in a hurry.
toki
http://www.modacar.com/product...APUK/ so this price is for 3 pulleys? or is it just 3 pictures of one pulley?
red240ne
Car: mmm...donuts
i don't see why these pulleys are such a big deal anyways. the crank pully doesn't really weigh that much anyways. i can support it with my index finger.
Xero
^^wow, you must be STRONG!! 'cause I picked up my friends spare pully, and they're ****ing HEAVY!!
toki
and also for $200 you will feal equal or greater benifits to a custom exhaust. it's a good power maker for the cost, and essential for N/A build up.
Xero
ummm...not saying that Import Tuner is the greatest mag ever, but they are owned by PRIMEDIA, either way, they got 9.4HP from peak to peak, from their U/R Pulley set, the SS set of 4. I'll scan the sheet if peopel really care, but they only got 5.1 on the intake, and 3.6 on the exhaust.
jrc90240sx
Well i dont recomend the ASP pulley, had to pull it off shorty after putting it on, and it has a hair line crack right where the crank stops. havnt contacted ASP about it so i dont know what they would do. its also on a KA24e engine. check about http://www.RPMoutlet.com i belive it cost me 90.
Xero
I believe ASP stands by their product, and mistakes CAN and WILL happen, they can't be perfect all the time. I bet that if you talked to them, they'll remedy the problem.
bruinbear714
The $400 you spend on the pulley kit can be used towards a nitrous setup.
Just go with the ASP pulley for $100 and save the $300 for something else. I've had it on my car for a year now and no problems whatsoever. The guy who had the bad ASP pulley might have gotten a defective one or something...
Xero
when you buy the $400 set, your getting all the pulleys, yes, but only the crank pulley is under-driven. The others are just made out of aluminum, that is lighter. So the $400 set WILL give more power, but only slightly, you'll get the core of the power back from the under-driven crank pulley, and ASPs is cheap, so I'd suggest that,
