pulley kit
turtle240
Car: 93 s13 koop
alright im getting an unorthodox crank pulley for my 93 coupe ka24de and my friend got a full pulley kit for his sr20 and the alt., water, and p.s. pulleys look exactly the same as my car could i use them or not
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Those pulleys are engine specific.
Barnav1t
Car: 1992 Nissan 240SX
just out of curiousity, what are you trying to gain with the pulleys? I only ask because I got the unorthodox lightweight underdrive pulley and didn't gain anything... I got more out of yarding out my A/C.
turtle240
Car: 93 s13 koop
no ill get a quicker rev and less crank drag
Barnav1t
I am willing to bet good money that you will HONESTLY not feel any difference. If you want quicker revs and less "crank drag" (I assume you are talking about inertial mass?), buy a lightweight flywheel.
2point4turbo
Car: 1990 240sx, 5 speed swapped, DOHC swapped,
agreed. pulleys = waste of money
locoluna825
Car: 90 240sx coupe
fiDANZA light weight flyweight 15+ hp to the wheels. dont buy the pulley kit but if you really want it JUST get THE under drive crank pulley thats the only thing that really makes the difference the other pulleys you wont notice.
http://enjukuracing.com/crank-...2_157
aka-prospect
would that pulley kit work for the ka24e?
locoluna825
Car: 90 240sx coupe
the one i gave the link for is for the ka24e or de depending on which one you pick "use the pull down menu"
visser003
Car: 1991 Nissan 240sx Coupe
Pulleys have also been known to add wear on engines.If you want to know more search around a bit, I remember reading a couple long threads about it.I would link you but I'm one lazy bastard.
locoluna825
Car: 90 240sx coupe
this is true reduced weight pulleys and flywheels do cause wear to an engine only because the those items were balanced to the crank of the engine when it was assembled. if you were ever rebuilding an engine and had the money to have a light wight fly wheel and harmonic balancer/(under drive pulley) balanced to the motor you would have very nice results
joenismos15
Car: 1995 Nissan 240sx SE
what you would really want if you just have to get a Crank pulley is a dampner;
http://www.phase2motortrend.com/atiendadoka.html
a little pricey but it would would work and not have to worry about the extra wear and tear that a plain Jane light weight crank pulley would do. it also has timing marks on it unlike the UR crank pulley and the OBX crank pulley's i had previously.And it is harmonically dampened
positron1
Dinan BMW - The Dangers of Power Pulleys and Understanding the Harmonic Damper
http://www.dinancars.com/bmw/t...amper
