lightsout »
https://forums.nicoclub.com/lightsout-u71638.html
Fri Aug 17, 2007 12:16 am
i just went through all this.my bad cylinder was #6.
take it to a dealer, and have all your sensors scanned through their scanner for open circuits. i had 6 bad sensors. primary ignition control unit(not a sensor, but computer problem)bank 1 Oxygen sensorbank 2 Oxygen sensorbank 3 Oxygen sensorcamshaft sensorcrankshaft sensoridle control sensor(on bottom of throttle body)....all were replaced and cleared.
i had all 6 coil packs that were worn out, and all spark plugs were tired too...in addition my primary ignition control unit needed to be reprogrammed.
Nissan recommends that if you have a misfire you should replace all coil packs, spark plugs, reprogram your primary ignition control unit, and clear the codes........so that was done and she drives like a dream!! I let the dealer replace the rear coil packs and spark plugs because i was not willing to take apart the upper intake manifold and remove all the electronics to get to them.
my problem was;as i replaced 2 sensors at a time, and the PCM could read the car better and showed that other sensors were a problem, so i got a 2 sensor codes at a time...and spent more time scanning it at autozone than actually working on the car, but i saved LOTS of money by doing most of it myself.
i would highly recommend taking it to a dealer and paying the $100 to have the dealer scan all your engine sensors for open circuits...then buy the parts through pepboys/autozone/napa like i did, and replace the ones that you feel comfortable doing. I'm sure U have a couple oxygen sensors that are bad...if you get a "open circuit" on those, I'd replace them first. Also, take off your intake components that are located just in front of your throttle body, take a look and see if your throttle body is grimy/oily/sutty...if so, take out your throttle body and clean it with DEEP CREEP(made by sea foam, get it at NAPA only) or another good name brand throttle body cleaner. Feel free to wipe around inside the throttle body with a shop rag and Qtips...while you've got it out check your Idle Control Sensor(at bottom of throttle body) for an oily plug. cleanse accordingly with the proper cleanser for electrical connections.
keep me posted because I WANT TO HELP!!
good luck,Lightsout
PS please post all the cods you have been receiving from your OBD2 scanner from autozone. thanks
Modified by lightsout at 3:29 AM 8/17/2007
Modified by lightsout at 3:34 AM 8/17/2007
