Puddle of oil under 93 Q45
Alcyone
Car: 93 Q45
Last week I noticed a puddle of oil underneath my 93 Q45 after it had been parked all night in my driveway.
Beforehand, when I was driving it, I thought I noticed a faint smell of burning oil, but it wasn't enough to cause me immediate concern. The engine was running fine as well.
Upon brief inspection, I can say the oil filter is tight and the drain bolt on the oil pan is good. However, the oil appears to be dripping from somewhere above the oil pan. It's hard to tell exactly where it's coming from because I have no safe means to get under the car to look properly.
The leak was enough to cause substantial oil on my driveway, but there was still a level registering on the dip stick.
Does anyone know what the likely source might be? I believe the car had been leaking for about 3 days and got substantially worse before I noticed it.
I'm thinking, perhaps, it could be the oil pan gasket.
Is there anyone locally in Colorado (denver area or northern colorado) that would be willing to fix it at a more reasonable price over dealerships and independent auto repair shops? I simply don't have the time or means to do it myself.
Thanks in advance for any help.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Likely sources would be the front main seal or the valve covers. NAPA might have a good shop in your area and have a good warranty program.
superuber
Sounds like valve covers. Have they been done? Be careful who you have do it. RTV, no gaskets.
Q45tech
Almost everything that could leak on a VH45 is best done by an expereinced expert..................too many average mechanics make mistakes from not doing the work regularly.
Someone who works on Q weekly is the best bet.
Alcyone
Car: 93 Q45
Thank you for the replies. Are valve covers an expensive repair? Are there any special things i need to tell the mechanic who replaces them to ensure the job is done properly?
sdkhalsa
Car: 94 Q45 06 M35
Check for a leak in oil pressure sending unit, this can really really pour it out. One person on this site mentioned that he had a blow-out which almost cost him the engine. In my case, I was loosing almost two quarts per week. It is a real bugger to replace, but there are some instructions in previous post.
96Qowner
Car: 1996 Q45
Replacing the valve covers gaskets isn't exactly cheap, no, sorry. The experts charge 7 hours for the job. The passenger side is pretty straightforward - driver's side isn't. Here's a thread with pics and details for the driver's side. It would help to print it out for the tech who does the work.
zerothread?id=107690
Alcyone
Car: 93 Q45
Took another quick glance and the oil pressure sending unit seems like the more likely culprit. I'm going to attempt the repair myself. Is there a how to guide somewhere? I did a search here but didn't find much.
sdkhalsa
Car: 94 Q45 06 M35
Try This: zerothread?id=267968I would also recommend dropping the sway bar(maybe mentioned). It does not take much time and yields great rewards.
Alcyone
Car: 93 Q45
Thanks. I'll give it a shot.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
also put a jack under the engine and lift it an inch or so--it GREATLY increases access.
Alcyone
Car: 93 Q45
Upon further investigation, I discovered that the oil is leaking out with the engine off. I poured 3 quarts of oil in and it immediately came out into a pan I had sitting underneath the car.
That being said, I don't believe it's the oil pressure sending unit or the valve covers.
What else could it be?
Thanks in advance for any further help.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Cracked oil pan? How else could it appear so quickly unless you left the bolt off?
Please complete your profile so we know what car and model we are talking about.
Alcyone
Car: 93 Q45
Well I don't recall bottoming out or anything. And I've checked the bolt and filter. I'm inclined to believe it's the oil pan gasket but don't know why it would begin to leak so quickly.
I'm not sure if it's related, but a couple of weeks before I noticed the leak I recall hearing a loud chiseling sound coming from the engine when I moved the gear shifter from park to drive. I put it back in park, restarted the engine and the sound went away. Perhaps this was timing belt slippage?
Modified by Alcyone at 9:09 PM 10/11/2007
Q45denver
1990 Infiniti Q45
Loud noises aren't good. You don't want to be running the engine until you have it checked out. Oil pan uses RTV not gaskets. No timing belt but chain. Most common cause of catastrophic engine failure is broken timing guides. Infiniti of Denver probably still has some experienced techs.
Alcyone
Car: 93 Q45
I definitely won't be starting the car or driving it until it's fixed. I'm aware of the timing chain guide problems on some of these cars. Could this be the cause of the leak?
I wasn't sure what RTV is and briefly looked it up. Is this sealant prone to leakage like gaskets?
Q45denver
1990 Infiniti Q45
If you are leaking that much oil it is not a gasket or seal issue. You may have a hole in the pan or block.
Rex
Car: None
If the guides "went", you could have experienced some kind of damage to the oil pump, etc that's on the front lower part fot he motor. Guide "pieces" usually go down there and do the most damage.
Alcyone
Car: 93 Q45
The problem turned out to be a crack in the oil pan. Although I don't recall hitting anything or bottoming out.
I'm going to fix it with JBWeld but need to give the oil time to completely drain from the pan so I can get the surface of the gouge clean.
Alcyone
Car: 93 Q45
JB Weld stopped the leak. 5 bucks later and all is well...
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Glad to hear it.
szh
Car: 2018 Tesla Model 3.
Alcyone wrote:JB Weld stopped the leak. 5 bucks later and all is well...
Hmmm ... I am not sure that I would rely on this for a long-term fix. I'd be safe and replace the oil pan. You can get them for relatively little cost, I'd think.
Z
yodawill2000
Car: 94 Infiniti J30
My thoughts exactly.At least drop it and get a good weld inside and out.
