NolimitZ32 wrote:When cold it should show either infinity, 1 (not 1 ohm but 1 as in open loop), or drop off to 0, when hot it will show in the MegaOhms, my good one doesn't go to infinity when its hot but still works just fine.
Hmm, When I test mine off the car and cold, obviously, it shows it has resistance. I know you did a write up or had a the testing procedures,and with what the test said, it said the PTU was good. But, I ended up finding out from another FSM that it shows mine bad. Im just really confused. That is why I was hoping someone would give me actual hard numbers if anything comes up.
Here is my issue, I am dead in cylinder 4. Here is what I tested;
Compression- 150psi, shows 5psi higher than cylinder 2
Coil pack- test fine, even switched with a known working pack to double check and all is good.
Spark- It has it, just seems weak, even on cylinder 2, but not as weak as cylinder 4
Injectors- Good, shows 12ohm at the actual injector, 10ohm at the terminal from ECU. Even checked them at CAS, it clicks and sprays. I alos replaced them with the newer style about a month ago.
Wiring-Good order, has connections no breaks.
PTU- See above
My only concern is the ECU, just don't have an extra one or know someone around here, just moved to Denver. I even drove the car from Phoenix to Denver with zero issues. It just decided to go bad out of the blue. Easy driving, cruising, just went dead. Only that cylinder, all the other ones are working just fine. Any insight?
