nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Mon May 26, 2014 12:58 pm
If you are only getting one side to fire, might need to check your timing belt, may have slipped. CHeck to make sure the injectors are actually clicking, you can always do this by taking out the CAS spinning it slowly with the key to the on position and either a stethoscope or long screwdriver. This will tell you you are at least getting fuel. Spark is just taking the coil pack out and seeing if it sparks.
