clev »
https://forums.nicoclub.com/clev-u125757.html
Wed Apr 08, 2009 10:33 am
Once you remove the outer door cover/trim, there is a squarish black plastic panel about 15x15"" in the center of the door. There are 4 bolts that screw directly into the two window tracks and ~10 bolts around the outer edge of the panel. When you remove the 4 bolts, the window tracks are loose and the window will fall. If you're going to attempt the job, remove the outer 10, have some one hold the window, and then remove the 4. Cables are attached/through this panel and we worked around them. We used spray on headliner adhesive to hold the insulation in place. The drivers side door, was easy, but we worked on the passenger side for a couple of hours, 2 days in a row and destroyed the window film/tint; $40 to replace it. The rear doors were no problem; remove the outer panel, peel away the plastic sheet, and you have access to the inner part of the door; nothing like the front.
While we're on this, has anyone removed the seats and back, side interior panels? We'll be doing that this weekend and don't want any surprises. I'm a little concerned about the side air bags
