Howdy folks! So, after struggling to find a massive vacuum leak for a bit today, I managed to discover (after pulling my charge pipes) that the turbo inlet pipe is leaking, and badly at that. (I had the entire intake system charged at ~10psi). A local mechanic and I had the engine out replacing manifolds and all that jazz - I bought nice new inlet gaskets, mechanic added a bit of "Right Stuff, black" to help ensure a good seal on the inlet->turbo pipes, but despite this... well, leak, of course. What I'm trying to figure out is, is it possible / feasible to remove the inlet pipe without pulling the engine to try and re-seal it, or should I just plan on pulling the engine again? The second bolt I need to get to SEEMS to be somewhat inaccessible, but any tricks you guys know of to get around that?
(For reference on space constraints: MSP manis, 2530's for turbos, stock heat shields installed )
Any advice at all would be greatly appreciated
