PS making sound
wilfonzo
Car: s14
i recently swaped motors and when i did so i unbolted the PS pump and put it aside while i did the swap and when i went to put back in i couldnt get 2 of the bolts in so i left it and now it makes a horrible high pitch whine is the tension of the belt pulling the pully off axis causing the sqeauling or is it something else
onosqv
Car: '92 240sx Vert
I'm guessing you need those bolts back in.. haha.
Seriously tho, It's probably a loose belt since you don't have the power steering pulley correctly mounted. Either get it mounted correctly, or take it off - those are sort of your only 2 options.
Take the belt off, turn on the car - shouldn't be making any more noise.
Now put the belt back on and tighten it down to factory specs or "pretty tight".
If it still makes a sound, your pulley may be gone - my tensioner pulley actually separated from the bearing itself - which caused the pulley to not spin always and make the nasty squeak, you can check that too.
wilfonzo
Car: s14
actually im pretty sure i forgot to tighten the tensioner pully ill try that, thanks
