W O T »
https://forums.nicoclub.com/w-o-t-u75991.html
Mon Feb 09, 2009 3:03 pm
Well I know how Ive always done it and I know alot of alot people use this method for P/S flushes (if youre not changing any ps parts out anyways)
You just crack open your PS fluid resevoir, pull out the filter (keep clean dont put it on the ground or anything), and use a turkey baster to pull out the 500ml of used fluid from the resevoir, empty as mch as you can, then fill it up with new fluid, filter, cap. Go for a drive around the block and make a bunch of turns, pump the fluid around, pop the hood and do the turkey blaster again, put in more new fluid. You can flush it 2-3 times and your fluid will be fresh as day lol
I just did it this afternoon, used 3L of ATF to do the flushes and final fill. And a 4L jug of atf is like $12 and a turkey baster i bought at the dollar store...
Im sure you could just crack a line at the bottom of the system where it meets the rack, and get rid of all the fluid at once, but I hate to touch old aluminum fittings and brittle connections... just my choice
