DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Mar 07, 2005 5:12 pm
Do a ratio to see how much you have after x flushes. E.g., if you get 80% out each time, then after 2 flushes you have (.2x.2) = 4% old fluid, or 96% new fluid. Meaure out the amount removed and compare to full system capacity. Note that HICAS cars have ~2x as much fluid as non-HICAS, but reservoirs are the same. Maybe only 30-40% new fluid each time.
