Postby
OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.htmlSat Feb 09, 2013 7:26 am
Does anyone have a way to get the part numbers for the Power Steering high pressure banjo bolt (also called an internally relieved bolt) from a 90-93 and the 94-96 base models?
I need to replace the banjo bolt to stop a small leak that has been with the car since I've had it. I have a source for the 94 model but I'm trying to determine if this is the same bolt used on a 91.
There are two banjo bolts on that high pressure line. Are both banjo bolts the same part number?
Most of the PS parts between a Phase 1 and Phase 2 G50 have some differences that I've seen.
Postby
OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.htmlSat Feb 09, 2013 4:57 pm
I think both bolts are the same part. Also, the bolts appear to be the same between the 90 -94 and 94 - 96. I'll need to get some new copper crush washers for sure.
