Edub1 »
https://forums.nicoclub.com/edub1-u34344.html
Mon Nov 14, 2005 12:55 pm
Thank you. I'd appreciate if you would post those files. Am I correct in assuming that you have used these to tune your ecu?
Anyway, I've been looking at those programs with some N/A tunes that some guys posted. I understand basically what needs to be done but I can't seem to figure out how to use the software. For example, I open "high octane fuel map." Across the top there are number +0 to +F which are hex values but for what? What does this top row denote? The column to the left shows 0C00 to 0CF0 - once again, I know this is hex but what do these values denote? Essentially, what are the x & y axis representing?
To the right there is a scale titled RPMs. This contains some more mystery data 60 - 600. What do I do with this? Below is a chart with a title Boost with 0490 beneath it and other data - what does this tell me? I'd upload the screen if I knew how. Anyway, any help would be appreciated.
