My name is Preston, I'm from a small town in NC, I'm 21 and I have 4 years of mechanical experience. I currently work at AutoZone but that is subject to change. On to the car...
It's a 90 Na 2+2 5 spd ttop.. It's been used and abused. 176k on the clock.. It was my brothers car for a few short months. He purchased it for $1500 after he blew up his 93 na auto after a very very long head gasket up "rebuild" which I helped quite a bit with. The death was caused by the infamous idler pulley stud.
Immediate plans:
Find & fix No brake/Interior/Low beam/Dash lights mystery? Third brake light works.? Tips?
Fix exhaust leaks at header flanges
Make sure old style injectors are working properly
Check timing
Replace worn out suspension bushings with urethane
Replace toe-worn front tires (245/40/18) Rear(275/35/18)
Replace noticeably shot power steering rack bushings & front end alignment
Service Trans & Diff. Best gear oil?? GL-4. Anything better for an old grindy 5spd?
Adjust E Brake
Replace Power steering pump. Currently running no PS belt due to a very bad pump.
New T Top weather strips
Replace timing belt & components along with the upgraded idler studs
Long term goals:
Mild Na build, lots of suspension work and fat trimming for fun track car/mountain twisties/drift
Install stillen headers
Install Unorthodox Udp kit
Coilovers
Install as many urethane bushings as humanly possible
Delete as much crap as possible Egr, Coolant pipes under intake, The crap in the inner fenders, and whatever else is possible..
Fix the front clip. Bumper is held on in two spots with cute black zip ties.... Face palm....
2j swap? This is more of a dream. Come on winning lotto ticket :P
Anyways I'm sure you're tired of reading by now..
Glad to be a member here. I'm open to suggestions, tips... Anything helpful!!
Thumbs Up
