Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Jan 12, 2005 8:45 pm
I had an idea tonight... What if I put an additional fuel filter between the "foot" on the pick-up and fuel pump? That should help protect the pump from the garbage in the gas that eats one every 80K. Sure it would be a pain to replace every year, but from a cost standpoint - if the pump lasted 200K and the only cost was an o-ring, a filter, and an hour or two of my time every year - it might be worth it.
The question is... would this work? Could the pump handle the restriction of the filter on the pick-up side? Also, should I use a large OEM metal filter or something else? The only other consideration would be if the filter would interfere with the fuel gauge sender...
Heath
