pros and cons?
giorod10788
Car: s14 240
Anyone know the pros and cons of using ichiba conversion 5 lug hubs on front and rear of a s13?
mychalous
Car: '96 240SX "Silvi"
The Ichiba hubs are some of the best on the market. Just buy them.
Razi
Car: Moo
Pros: Easy way to find a 5 lug swap
Cons: They have bearing problems
Dittoz7
Car: 1997 2f0WtY SE!
Pros: Having the same number of lugs as Dittoz7
Cons: Not actually being Dittoz7
giorod10788
Car: s14 240
Do I have to change the spindle for the rear or is it direct bolt up to the stock one?
Razi
Car: Moo
Bolts right up.
pj
Car: 95 s14
Razi wrote: Cons: They have bearing problems
you can buy them without bearings i thought, just use oem bearings?
Razi
Car: Moo
I heard some people trying to do that.
I always thought the insides were a little bit different than OEM and couldn't be swapped.
I've seen people swap them out with high quality bearings from some internet sites though..
pj
Car: 95 s14
Razi wrote: I always thought the insides were a little bit different than OEM and couldn't be swapped..
id be willing to bet you are right, that really wouldnt suprise me at all.
i only ask because i havent decided if ill go 5lug or stay 4 and rock a little spacer. anyway, thanks
Razi
Car: Moo
No problem!
If you're lucky at the junkyard, you could always find some Z32 or S14 hubs.
Currently I'm running some S14 5 lug hubs, still going strong!
