Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Mon Jan 24, 2005 2:15 pm
not necessarily...you may increase the slip angle (its really an increase in force, not necessarily slip angle in this case), but the car understeers naturally anyways due to weight distribution and supension settings, and beacuse of weight transfer, you rear tires will gain a bit more traction under throttle.
THeorhetically speaking, a slightly understeering car would, under throttle enough to maintain cornering speed, be very neutral due to the factors above.
this changes, obviously, with other conditions...but the premise is the same.
inducing more oversteer by use of extra throttle and compromising your front grip (weight transfer) isn't the best solution, IMO....unless that was a limiting factor...
In theory, the difference between the unloading of the front tires(and their grip capacity) would be the same as the loading on the rears less traction loss (driveline force)keeping the car neutral...
Coplex sequence of events...now you can induce oversteer with too much throttle(torque) loading making it reache its dimishing returns and your tires ability to resist the forces finally give and slide out...
by the end of the apex you can increase throttle naturally because cornering loads come off the tires anyway. Using throttle before that is just compensation.
larger rear tires can icrease your rear traction, but this should only be used if this islimiting your conering force, and with most 240's..that isn't the limiting factor.
-Chet
Bali: COol..its up to you....your car
