poshatch »
https://forums.nicoclub.com/poshatch-u145419.html
Tue Mar 16, 2010 1:23 pm
so ive had my s13 for awhile now and ive done various suspension mods to it
here is a list of some of the things i have done that is probably important to this post: Tein HE coilovers, front tension rods, rear upper control arms, rear traction rods, rear toe rods...
now im sitting on some 16x8 wheels with a 205-45 on them and since i do...i have it lowered as low as i possibly can without drooping or compressing the springs to make it look ok
I KNOW this is too low for proper operation of the suspension, as well as running into problems such as bottoming out (horrible to DD), and just recently at a skid pad event i bent a tie rod bottoming out...
now im completely over trying to have my car look cool and i want the proper set up, this is the info i need from you all:
just let me know how you got your car set up or the proper way to have a s13 set up (pictures or however you want to try to help me out), i would like my car to put out greater cornering performance then the way to low suspension with the lowest possible center of gravity, i plan on running wider tires with a lower sidewall to help flush out the look of the car and improve grip
the set up is for drift and good balance and minimal roll is KEY!
got lifetime alignments so id like to get the car set up properly, change the tie rods to some thicker ones and ones that are meant for lowered cars, and take it to get aligned
i also got a suggestion of switching to s14 lower control arms and that would help fix the geometry from the lowered car
lookin for advice from people who have drifted for awhile and can offer good advice,
thanks all
