SlickRick90TT wrote:9 wide. I dunno the offset, but they clear the brake calipers.
275/35/17 is ideal, but an impossible size to find. Would fit fine, but depends on the off set. They're probably the +35mm version, so you have no problem with that size. Do it in all four corners for the best handling and tire life. Staggered set ups only work if the front and rear wheels are different widths. Running different size tires f+r on the same width wheels is stupid.
265/40/17 is more available, and there are some great tires in that size.
