cencia76 »
https://forums.nicoclub.com/cencia76-u144084.html
Tue Sep 29, 2009 3:36 am
Hi Q45tech,
thank you for the reply. I am a bit confuse on how to use the BG109 or the QC from BG. I have found the following info in this forum. Would you have any comment about those two statements?
Statement 1: "bg 109 is it, the new stuff, you can use it with dirty oil before an oil change!!! I know, I know, dirty oil, but this stuff turns carbon into a waterlike substace! If your lifters are ticking and your engine vibrates a little; try it, but use bg MOA in your oil after this amazing stuff is drained."
Statement 2: "Get the following: 1 can of bg QC; 2 cans of bg MOA, FRESH CLEAN OIL (go buy cheap oil, and filters from wal mart). Add a HALF a can of quick clean and one can of bg MOA and follow the directions on the quick clean can (warm car, add QC, run for 10 15 minutes, change oil) and then repeat the foregoing proceduce RIGHT AWAY changing the oil WHILE ITS HOT each time. After the two flushes use your normal filter,oil and additive, but bg moa is some good additive. Why two flushes? Because if your too agressive, you could trash your engine!"
Do I have to follow procedure 2 even if I use BG109?
If you think that I should use QC, then do I need 3 can of MOA? 2 for the two flushes and 1 for the with the good oil?
Thank you for your help so far.
