i got the car home and immediately started maintenece lol
so far i have replaced
z32 fuel filter
valve cover gaskets
cleaned egr and tb
oil change
new plugs
transmission wise-if most of you recall i had a thread earlier on about the transmission issue and by process of elimination and alot of swearing i found out what was wrong with it lol.shift solenoid A
so i ordered new solenoids and in the process of removing the solenoids the old gasket between the valvebody disentigrated so i ordered the gaskets new as well.one month later after the parts arrive i set everything down on a nice clean table and start tearing the vb apart
the Q runs beautifully
by this time the transmission had gotten alot of attention
i had replaced the vb gaskets
shift solenoids
o rings for solenoids
transmission filter
fluid drained and filled till nothing but red fluid showed
new transmission pan gasket and new fluid with half bottle of lube guard RED
after the q was up and rolling the stock ride height had to go so i searched and searched and came across z32 stuff on a Q.
i quickly serahced local forums for a z and found what i needed.
i ordered new struts and went to town
i still have some tweaking to do in the rear so level it out but tell me what you guys think!!
P.S.-thanks to all who helped me through this
now im still on the lookout for a hood and grill,just pieceing this bad boy back together.lots more maintenece needed still
