I assumed that I needed to perform the cold weather fuel line check procedure but decided to let the car sit (its a second car) until the weather warmed up to be sure. Well, today we got nice temps in the upper 70s and I had a little time. I got most of the fuel line clamps tightened up and decided to do a test. So I started it up, walked around to look under the hood to check for leaks...and was horrified to see a strong stream of fuel spewing out of a burst hose. I mean, I could hear a ringing noise from the sound of the fuel hitting against metal.
Some history: [My original engine died 4 years ago (258K mi) and just a couple of sad days before the J30t was to depart to its final resting place I received an great (i.e. $$ cheap) offer to replace the engine with a used one. Payment in advance of course. 14 months later I actually get the car back with the used engine after showing up to the shop several times unannounced with expletive laced encouragement. So I have no doubt corners were cut to complete the job.]
Any recommendations or advice on hose for fuel lines? Thanks.
