Ace2cool:
Doing more research on other sites...it appears that the pressures will be somewhat higher using R134a when retrofitted.
Here are the pressures at an ambient temp of 78 degrees with doors closed, windows open part way, on max air, recirculate button pushed and box fan positioned at the nose of the car.
Low side was 30 to 32 psi
High side was 200 to 225 psi
These readings will change with the outside temps.
You must have the car fully warmed up and AC on before attaching good AC manifold gauges and taking the readings. (turn the engine off before attaching the gauges then restart the car).
Now I have a new question...
My recirculate door apparently is not opening and closing all the way. It may be jammed. Does anyone have a step by step guide on how to get to it to either un-stick it or fix it? The online service manual (
http://300zx-twinturbo.com/cgi-bin/manual.cgi) is not very helpful.
