another question...Densetsu wrote:I'll eat a couple of my words, because while there's only one grease fitting for the '04, there are more for the '99.
Maintenance section of FSM for '99 -- see page MA-24. Can be as many as six fittings. No mention of any other grease fittings in this chapter.
Maintenance section of FSM for 2000 -- see page MA-26. Only one fitting. No mention of any other grease fittings in this chapter.
Best bet is to check the maintenance chapter of the FSM specific to your year. http://www.nicoclub.com/FSM/pathfinder/
Perhaps because the transfer case on the 4x4 requires a shorter drive shaft?Towncivilian wrote:Hmm, odd. I'm unaware of any reason why the main driveshafts would need to be any different between the 2WD and 4WD models. I will have to update the general info thread to reflect this.
Sorry to raise a pretty well rested thread... but what happens if one does unexpectedly pump the grease gun until grease starts coming out of the rubber seal?alexf20c wrote: it's called a slip yoke and you're NEVER supposed to keep greasing until you see the old grease come out.
