alexf20c wrote:nothing in the diff should be pressurized, that's why there is a breather tube, to vent any pressure build-up from gear mesh. if you overfill, it can come out at the outer axle seals (inside the brake drums). that's also the first place you'll notice a leak, other than the seal between the case and the housing.
check the insides of your wheels, and inside the brake drum. they could be saturated in gear oil from a bad axle seal, which could be caused by well - a bad axle seal; or it could be a clogged breather hose which is allowing pressure to build, and blowing it out the axle seal.
Thanks for the reply alex.
I took a quick look down over there and also took a few pics. I cant seem to be able to post the pics here.
But it seems to look ok as of now, as in no leaks. But I will look again. I am concerned cause it took a whole 1.5 quarts more than the FSM requirement of 3 qts. I went to the nissan dealership nearby who are are turning out to be utterly unhelpful going by my last few visits there. They simply offered that they could do it for me again and that they have no idea whats going to happen with the overfill. Basically, they never really answer my question other than to offer to do XXX for YYYY everytime I go there.
I will try to posts the pics again. But thanks for the tips. Theres so much I am learning here.
