ProjectSilvia and Courtesy Parts FMIC Piping
CoupedUp
Car: 1993 Coupe
What is that 1" Bung for on the Lower Hot Pipe piece?
http://www.courtesyparts.com/M...104-3
What is that for? its on both kits which im sure are identical.
Is it for a JGS Style BOV?
Any suggestions on blocking that thing off?
karmakaze
Car: 98 240sx SE
i
CoupedUp wrote:What is that 1" Bung for on the Lower Hot Pipe piece?
it is for a BOV. you can get 1" rubber caps for it. but why do that when you can put a BOV on it?
CoupedUp
Car: 1993 Coupe
Hmm, thatll put my BOV really low, like only 6-7 inches above the bottom of the FMIC. I see now that my Hot Pipe will route right below the PS resevoir in the opening. I guess itll keep the engine bay less cluttered but, oh well. Ill have my Modular Flange welded on there i guess.
Tulsa_S-13
Car: 1991 SR 240sx
I'm surprised you didn't realize that's for a BOV, I asked you about that not too long ago!
CoupedUp
Car: 1993 Coupe
I know david but its so freaking low and and oddly placed on the piping.
The way it looks. Ill have to cut into that metal part where the stock box filter was. Or it might be under that. O.o.
CoupedUp
Car: 1993 Coupe
The BOV would be visible right there if my piping were on your car. The BOV would be pointing back to the right and towards kind of the rear tire. It wouldnt project into the engine bay.
highmilehatch
If you've ever seen how the factory recirculation valve and SMIC are setup, you would notice that the valve comes off of one of the pipes for the SMIC. Those piping kits assume you are you using the factory recirc valve, which is in that location. Most just cap it and use a BOV mounted on the hotpipe. I had a customer car with the factory SMIC, with an HKS SSQV mounted down there. Sounded pretty cool being on the outside of the car.
CoupedUp
Car: 1993 Coupe
Im not Venting to Atmosphere. Ill try and see if there is room. If not...Ill cut a hole in my Hot pipe and have my Modular Flange welded on there and cap that bung.
