Projectors and HIDs?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
sherb
Car: Versa
This is my first post just wanna say how great the site is. Just stumbled onto it and have already done a bunch of reading.
Just wondering if anyone has any recomendation on where i can get projectors and HIDs for my 09 versa? (yes i've googled) just seems there is a lot of talk of what the best color temp is and 35w vs 50w, etc. i'm intrested in something that has both high and low beam.
also if anyone has installed them how difficult is it?
Thanks.
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
Use the search button in the top right corner.
sherb
Car: Versa
i have used the search and found some stuff that seems intresting but i'm wondering what i need to know about combining the projectors and hidshttp://memimage.cardomain.com/...e.jpg look like good projectors for the car. but i cant find any info on them from the post zerothread/292669 that post was made in 07 do versas still use the same parts? if so does anyone know where i can obtain projectors like that and what would be the best hid kit to fit with them?
sorry for what seem to be basic questions. this is my first aftermarket purchase.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
the projectors in that pic are JDM and will run you upwards of 1200, there is another set of projectors that some of the people from here have that is more affordable...
sherb
Car: Versa
any chance i could get a link to a site carrying them? Can they handle HID bulbs?
Thanks.
mo_hish
You should just get used ones, I just bought a set for $50 that work perfectly. Check the classifieds on various sites.
superskunk
yes... i have a set of 35w 6000k installed into my stock headlights... with a little bit of adjustment they work just fine...
mo_hish
you can basically customize most headlights with a little bit of adjusting.
Red Devil
sherb wrote:any chance i could get a link to a site carrying them? Can they handle HID bulbs?
Thanks.
Unless they are projectors DESIGNED to use HID's then no. There are halogen projectors out there just like there are HID reflector housings as well. If you want to do it the right way, i.e. harder and better looking way, you need to retrofit HID projectors into your stock housings.
Return to “Versa Technical Discussions”
