Projector Headlights
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
sublime1434
Car: 2009 Nissan Versa
Found this item and I am very interested in it. http://www.slickcar.com/produc...=7103 I was wondering if anyone knew if I need a different type of plug for the headlights. Projectors have a hi beam bulb and a low beam bulb correct?? If this is the case then the single H4 buld is not goin g to cut it!
weems84
Car: Versa SL
no special plug needed. It is a plug and play. Stock harness plugs into a single harness on the headlamp. If you want to do HID minor modifications are needed.
Urq
Car: 82 Ur Quattro & 07 Black Versa SL CVT.
So does anyone have them on there car and if so how is the quality and figment?
deal08
Car: 08 Nissan Versa
Urq wrote:So does anyone have them on there car and if so how is the quality and figment?
zerothread?id=347325
Touch524
Car: 08 Nissan Versa SL 1.8 CVT
[IMG][img=http://img32.imageshack.us/img32/1184/versa.th.jpg][/IMG][IMG][img=http://img188.imageshack.us/img188/3964 ... 52k.th.jpg][/IMG]
Projector housing with 6000K (dimond white) HID !!!!!!!!!
Return to “Versa Technical Discussions”
