streetmekanik »
https://forums.nicoclub.com/streetmekanik-u82934.html
Thu Jun 30, 2016 4:01 pm
Hi, yes I believe so, as the S12 came with the CA18ET, the forerunner of the CA18DET. Logically the engine transmission layout would work since, there a small block kits for the S13.
If you run a standalone ECU, and a full kit the job would be a bolt on affair, but not a simple one as there will be differences.
If you are wanting to do this for a small amount of money and use a donor car, it would be alot harder, but not impossible.
