Former_240_s14 wrote:must agree, stop daydreamin
RPS13guy wrote:all i was asking for was advice on how to turbo my girl with least possible work to her internals, but you guy's spat on me and for that ya'll can suck my exhaust pipe and die. this is a public forum, if ya'll ain't got advice, don't give it, but don't knock my s-hit, it just makes you look ignorant and green. grow up kids, and learn how to get along with people that might in the future help you're stupid a-s-sses with a project. :patriot :
C-Kwik wrote:So far, noone who responded to this gave any kind of a definite answer. Frankly, I don't think anyone knows what they are talking about. Seriously though, if you have a KA in good condition, 300+ HP is possible with stock internals. Just make sure you have enough fuel to compensate for the extra air. I'm not very familiar with Mitsu turbos, so I don't know if a 16G will be a good choice or not. Even if you build the motor, 7.5:1 Compression pistons is probably a lot less than you will need. For the HP levels you want, you can stick with the stock compression. The lowest I would ever go would be 8.5:1. To achaieve 300+ HP, you'll need to be boosting about 12-13 psi of boost minimally. Depends on the turbo you use. As far as a fuel rail, if you decide to use top feed injectors, you will need an aftermarket rail. There are side feed injectors available that will fit, but they tend to be pricey.
