I would post the dyno graphs, but they're pretty useless, with a 5500RPM stall in the converter you get some odd graphs. Just take it that the AFR at the muffler is 13.1:1 across the board.Unnatural1 wrote:EXTREMELY nice job! Everything looks top notch...especially for a track only car. Most importantly, it looks like you are satisfied with the end result of all your hard work. The VH45DE is a fantastic engine in my Q45 and I'm guessing it's an absolute beast in a chassis that is over a 1000 lbs. lighter.
I'd be interested in some more info on your dyno results. Can you post the graphs? Before and after the S-AFC/timing? Have you modified the ECU at all or just added the S-AFC?
Did you ever find and fix the misfire you were experiencing?
Since the car is on 103 octane unleaded, I upped the base timing by 10 degrees, which is where all the power was made. Honestly, I would have added more but the CAS couldn't rotate any further. The SAFC is pulling out a little bit of fuel, but not much. The ECU is 100% stock and the fuel cut issue is still there. The car is just quick enough now that it happens just after the traps rather than just before.
